The issue that I'm having is after creating a popnet flock animation, which is looking good but I can't find a way to make sure the mesh that is instances to these particles those not flip 360 around the velocity vector.
I've Found this previous post [www.sidefx.com] but is a bit old and wanted to ask if someone knew how to fix this.
Thanks in advance for the help.
Flock Animation - instances do a 360 flip! How to Fix this
1682 2 0-
- TiagoAndrade
- 1 posts
- Andr
- 899 posts
- mrCatfish
- 738 posts
What attributes do you have going into the sim? If there are no orient, N or up attribute, Houdini will orient using v. However, it has no way to determine the up vector and that's why you're getting flipping.
At the very least, give you source points N and up and this will probably fix it. You could post a hip file too.
Sean
Sean
Sean Lewkiw
Machine FX - Cinesite MTL
