Point rendering pscale multiplier
   6503   8   1
Hello All!
I'm very new to solaris and Karma and I was trying to do some point rendering with it.
Before, with Mantra, I used to set a point scale multiplier from the obj level geometry node
under Render->Geometry>Point Scale parameter witch acted as a multiplier at render time
before the needs to re process my point cloud or adding any post wrangle node to do it.
I wonder if there is something similar in Solaris/Karma ?
I had a quick look and I guess mostly due to the fact I know very little about this new tech
I could not figure something out.
Thank you in advance,
A
Edited by AlexNardini1 - Oct. 28, 2021 05:53:51
I don't think so, but it would be a good feature request for a karma render property--would bring it further into parity with mantra.
For now the only way is to edit the widths array with a wrangle/vop/python lop--or if it's coming for a live sop network do the edit before it is imported into the stage.
Thank you jsmack!
That’s a bummer tho, as I used to tweak my pscale for delayed loads too using the upstream geometry node, so handy….
So here is how I did it with a wrangle node inside Solaris.
int npt = usd_attriblen(0, "/sopimport1/points_0", "widths");
for(int i=0; i<npt; i++){
    usd_setattribelement(0, "/sopimport1/points_0", "widths", i, 0.0005);
However seem to be a bit slow from my tests
and I still dnt get how to use the option Run on Elements of Array Attributes in the wrangle.
I did try using
@elemnum
and
@numelem
but without luck, any help ?
AlexNardini1
make sure you are targetting the mesh node in Primitives parm
check Run on Elements of Array Attributes and then type this into wrangle code:
@widths *= 2;
Edited by tamte - Oct. 28, 2021 18:56:23
Ahhh, by default it was targeting the xform node…now it’s really fast!
Thank you Tomas!
Edited by AlexNardini1 - Oct. 28, 2021 19:19:53
Karma is amazing,
here is my run with it using a new version of my FLAM3 hda recompiled for H19.
Thank you for the help, I was blown away on how fast it is and the de-noiser work like a charm!
https://vimeo.com/640136970 [vimeo.com]
Alessandro, you're a madman!
Jason! Not as much as I lately wish I could have been.
Karma, Solaris and the rest…that’s real madness !
Edited by AlexNardini1 - Oct. 31, 2021 07:03:56
