where is the hqueue server install option?
   3978   6   0
Hey!
I'm trying to update my hqueue server. Unfortunately the hqueue server install option on linux is gone. (see the attached pic)
Where do I find the installation option now?
Best,
Andreas
Only available via the Houdini launcher
http://www.sekowfx.com [www.sekowfx.com]
Hey Andreas,
your first post here!
I just got the update to version 19 working
https://www.sidefx.com/docs/houdini/hqueue/gettingstarted.html#scripted-installationson [www.sidefx.com]
This was a good reference to get it done.
Some background information about the running setup before v19:
Debian Stretch without desktop environment, already running HQueue 18.5, all paths kept default. After a bit of tinkering the procedure was kind of straight forward:
(logged in as root, all files are stored in /root/ if not specified differently)
Download/upload the install_houdini_launcher.sh to your box and execute it
bash install_houdini_launcher.sh
install the missing dependencies to get the houdini_installer working
apt-get install libglu1-mesa libnss3 libxtst6 libxkbcommon0 libxss1 libsoundio1
Pick the editor of your choice and create a settings file with the necessary information, i chose ~/.launcher_settings.ini as a destination for it
#client_id="you can generate your API key within your account settings: services, Manage applications authentication"
#client_secret="but this didn't work on the first run with the following settings: Client type confidential, Authorization Grant Type client-credentials"
username="sidefx@your.tld"
password="obviously-your-password"
accept_eula="SideFX-2021-10-13"
Execute the installer and you should be rewarded with the message "Preparing to install"
/opt/sidefx/launcher/bin/houdini_installer install --product "HQueue Server" --version "19.0.383" --settings-file ~/.launcher_settings.ini --build-option py2
Sadly the authentication with the API keys didn't work, the installer just quit with the following error:
Error: Failed to log in: Error transferring https://www.sidefx.com/oauth2/application_token - server replied: Internal Server Error
Operation failed
With the normal credentials it worked just fine, but would be way better to just use the API instead.
- Sven
Thanks Sebastian & Sven! I'll give it a try. Hey Philipp!
Quick update. The launcher GUI failed because of some missing QT stuff. The command line way worked fine.
 --build-option py2
This (undocumented) flag is what made it work for me. Thank you!
Edited by ulyssesp - April 18, 2022 10:58:46
