Is it possible to import Material X presets?
   7979   9   2
Hi, daft question but are there any material x presets available in H19, similar to the ones found on e.g. the principal shader? Couldn't find any when I click the cog on a mtlxstandard_surface.
I can see some examples in the official materialx repo on github, is there a way to import those into houdini?https://github.com/materialx/MaterialX/tree/main/resources/Materials/Examples/StandardSurface [github.com]
Edited by Lyubomir Popov - Dec. 5, 2021 06:26:23
They aren't presets on an HDA yet, but they do ship with Houdini since they are part of MaterialX. You can find them in $HH/materialx/resources/Materials/Examples/StandardSurface/
The MaterialX standard test geometries and hdr lights are also in $HH/materialx/resources.
You can use a Reference LOP to reference a specific material from a file; attached is a hip file that shows how to do this.
Hope that helps!
reference_materialx_examples.hip (392.5 KB)
I'm o.d.d.
Thank you!
This works when I reference in one of the .mtlx files from the Examples folder. However, when I Right-click > Save > MaterialX (on a Standard Surface node for example), the resulting .mtlx file gives me this "Unresolved reference path" warning and no material. Any thoughts?
and how to edit the .mtlx referenced.
i drag the .mtlx from scene tree to path of edit materialnode.and then i press load and nothing happen.
what is correct method to edit the .mtlx ?
microvswind
It's working for me. Are you filling in the path to the material prim on the edit material network node?
yes.and the .mtlx mateial can not works above attached by @goldeleaf.
microvswind
The prim referenced in your scene is broken. there's nothing there to edit.
jsmack
microvswind
How to fix the prim referenced.
i create a empty scene and reference the .mtlx with this setteing.
microvswind
jsmack
microvswind
That's correct. The same referenced prim works correctly for me. Which version of Houdini are you using?
