Animation not showing in rendered sequence
   2721   2   0
Hi there,
I have animated a locator, imported the abc and parent constrained a light to it on the stage. It seems to work perfectly in the viewer and when I render it in red shift in the image viewer but when I render a sequence it doesn't animate. I see on a merge node I get the following warning;
Warning
Time codes per second metadata is inconsistent across time dependent inputs. Composition may not be as expected.
Any help would be much appreciated!
bro check the scene fps is mmatching with respect to cache filee scene
Try to put a cache node after the contraint node, and cache full range.
