Pretty smooth so far
   1715   7   1
Monterey 12.2.1
Mini M1
8 GB Unified Memory
Houdini 19.0.554
Install and such went very smooth - Houdini seems snappier on OSX.
Houdini Indie
Redshift 3D
Glad to hear it’s snappy! Are you able to use Arm native Redshift in this version of Houdini?
Hopefully Apple Silcon RS will be available soon’ish
Screen Shot 2022-03-10 at 5.59.09 PM.png (1.2 MB)
Houdini Indie
Redshift 3D
Daryl Dunlap
Juanjo posted a custom build of RS for Houdini 19.0.554 Apple ARM64 build just an hour ago: here [redshift.maxon.net]
Edited by joostkonemann - March 11, 2022 07:24:45
Anyone able to get RS to work using the Apple Silicon custom build….I get errors on H startup, and I “think” I gave permission to run the pylibs for RS, but then, I get crashes when I try to render or basically do anything with RS.
Edited by TwinSnakes007 - March 11, 2022 10:00:47
Houdini Indie
Redshift 3D
Daryl Dunlap
It's working fine for me. The first time you launch Houdini, it's complaining, then give it permission to open in system preferences and launch Houdini again.
I'm running the Houdini 19.0.555 arm64 daily build, with RS 3.0.66 with the custom build for Houdini 19.0.554.
joostkonemann
Daryl Dunlap
Would you mind walking me thru the giving permission piece? - I’m very new to macOS and its inner workings.
Houdini Indie
Redshift 3D
Okay, we've been racking our brains about why RS was not rendering, using the default install process - and there's still some kinks to be ironed out - BUT, there is a path forward in the interim.
If you follow these exacts steps, you'll be rendering with RS in no time on Apple Silicon.
Edited by TwinSnakes007 - March 12, 2022 10:45:36
Houdini Redshift Monterey setup.pdf (276.4 KB)
Screen Shot 2022-03-12 at 10.36.31 AM.png (372.5 KB)
Houdini Indie
Redshift 3D
