Trouble With PDG bulk fbx animation export
   6050   7   1
Hello, Im struggling with getting the pdg to export my modified animations to the directory I set. I keep getting an Error: Missing clipinfo detail attribute. Even though inside my geo node thats handling the skeleton has a "configureclipinfo" node right before the fbx animation output node that my ROP fetch inside the tops graph is referencing. Im pretty new at this so I think I'm doing something wrong. Im basically wanting to replicate what luiz does here @34:04 https://www.youtube.com/watch?v=mcDm_irEKb0&t=3095s [www.youtube.com]
I cant really share the files im working with because its a pretty big library of animations but I'll share my hip file so you can atleast see the node flow
Edited by GreggoryAddison - March 26, 2022 20:13:51
clipInforMissing .jpg (376.5 KB)
Retarget_And_Mirror_05.hiplc (542.8 KB)
This is the hip file
What is bothering me the most is that if I just export directly from the rop fbx anim output node it works flawlessly. Not sure why when doing it with the top network messes it up
hard to say without your fbx files
1. I'm pretty sure the expression in your /obj/geo1/fbxanimimport1 should be `@pdg_input`and not `@pdg_output.0`
2. and for me it started working when I returned external files multiparm in /obj/topnet1/ropfetch1 to default
Edited by tamte - March 27, 2022 01:07:15
tamte
For 1: Whenever I set it to input I get a warning telling me to provide a fbx file, didnt do that with output.
For 2: I have no idea what that is but I'll look around
tamte
Just check the External Files Multiparm and its set to 0, I havent touched it. Gonna give input a try
tamte
That was the solution. Changing output to input worked. jeez I've been bangin my head all day. Thanks for spotting that now I can sleep
glad it worked out
GreggoryAddison
you can ignore that one, I opened it in 18.5 which seems to have different defaults for that multiplarm
Edited by tamte - March 27, 2022 05:08:24
