Multiple file output per wedge simulation
3019
2
0
PatW
March 30, 2022 8:49 a.m.
Hi, I want to wedge pyro simulation and write each frame out along with an additional low res vdb I tried chaining rop geometry output but it saved all frames of full res first then processed the saved output for low res version afterward Is there a way to do this frame by frame, cooking both outputs in one go?
tpetrick
March 30, 2022 10:39 a.m.
In order to do that you'll need to create the ROPs yourself (e.g. two geometry ROPs in /out), and point a ROP Fetch TOP at the last node in the chain of ROPs.
Edited by tpetrick - March 30, 2022 10:47:41
PatW
March 30, 2022 11:57 a.m.
Thank you!
