How to merge co-planar primitives?
   4187   8   1
For example, from this:
To this:
In other words I'd like to dissolve all the edges that connect two co-planar faces. How could I do this procedurally?
Screenshot 2022-04-06 204855.png (174.8 KB)
Screenshot 2022-04-06 204919.png (181.3 KB)
You can do it using the Group SOP and Dissolve SOP:
If you have the labs
you can use `extract silhouette`
Also handy is the Labs Dissolve Flat Edges node.
Thank you all! I didn't expect to learn so much with this simple question :p
animatrix_
Sorry for the off-topic, but what setting are you using in order to mix 3D scene view and nodes together like in your screenshots? Thanks in advance!
Fuse - Divide (Remove Shared Edges)
kks_m
animatrix_
I wrote a custom Python Qt extension to do so. I talk about it in detail here (after 30 min or so):
Feel free to send an RFE to SideFX if you want to see this feature in H20
animatrix_
Whoa, very impressive! Love it.
animatrix_
Will do :-)
