how convert texture to .rat file for karma
4758 6 2-
- Piledriver
- 99 posts
- tamte
- 9417 posts
you can use iconvert [www.sidefx.com] command either from shell or TOPs
- Piledriver
- 99 posts
- tamte
- 9417 posts
- Piledriver
- 99 posts
- jsmack
- 8184 posts
Piledriver
for documentation i mean something that explain how use that command on top or something, that i'ts just a reference
type the command into the shell and it will output a message explaining how to use it.
As for setting up an automation script in TOPs, there's a node for searching for files with a pattern, and the shell node lets you build and run a command. Combine them and you can set up a system to convert all the textures in a folder matching a pattern to rat or mipmapped exr with imaketx. Good luck
- AhmedHindy
- 146 posts
for anyone looking into using TOPs for generating .rats for an entire library, here is a link for how to do it: https://youtu.be/L51DUKjrkIo?t=658 [youtu.be]
also I attached a screenshot.
