How to extract a point transfrom from an SOP to Solaris?
   2093   2   0
In /obj context, we can use Rivet Object to extract a point transform from an SOP.
How to do this in /stage? Is there something like "Rivet LOP"?
My use case is, for example, I have a curve in SOP context, and I wish the camera to move/orient along it.
Edited by raincole - May 9, 2022 05:12:41
It would be similar to obj level, with a follow path constraint. Although with obj, the constraint is created with chops, rather than with a lop node in /stage.
Btw, the rivet object should be considered a legacy tool. The current way to constrain objects is with constraints.
Edited by jsmack - May 9, 2022 12:40:30
raincole
It's called Points Constraint LOP [www.sidefx.com]
