How To Implement Separate Render Passes in Solaris?
   16757   21   3
jsmack
Like antc said, don't daisychain the karma nodes, they aren't rops. Each modifies settings of the node before it so you might get unpredictable results. For example, if the first karma node defines an aov, later karma nodes will still render that aov since it's on the stage.
I've attached a scene that uses context options to vary the visibility of objects on the stage with several usdrender nodes at the bottom of the tree.
Hi! I have tried out this set-up and it works great. I noticed some scripting in the interface of edit proprieties. Can you point to some documentation about it? Thanks
Stanley00
jsmack
To what scripting are you referring? I opened the scene I posted previously, and I didn't find any scripting.
