Ambiant Occlusion in mtlx standard_surface?
   6217   6   1
Could anyone tell me how to use and plug an AO map file into a mtlx standard_surface?
I used the node MTLX tiled image, then I got a mtlxambientocclusion node, but how can I use it?
G
Houdini gamboler
It's a bias generator that only works in CPU mode. You can use it to mix colors/ textures (or any signature type) based upon the angles of the surrounding geometry.
Edited by Enivob - June 29, 2022 12:04:40
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Thanks a lot Enivob for the very informative post.
I want to adjust the AO using an AO texture map, so I did this setup: see enclosed pic. Is this correct?
As you said, when I try to render with XPU, it doesn't work. Will this be fixed in future releases?
Edited by Grendizer - June 30, 2022 07:55:39
karma mtlx ao with node image.png (301.2 KB)
Houdini gamboler
Grendizer
I can't tell what you're after. You want to use the AO to blend between the basecolor and a ramp driven by the basecolor auto-cast to float (which would be the red channel usually)?
Grendizer
Who can guess what Sidefx will or won't support in the future unless they've announced it already. I suspect they aim for CPU XPU parity with mtlx shaders.
Well yes. The AO texture map is a black and white map (attached to this post). So I'm using the ramp to get a darker version of the base color and I plug it into the BG of the mixer. Then the AO map decides what zones are in normal color and what zones are in the darker color. I think it's the right setup but I just wanted to make sure.
Edited by Grendizer - June 30, 2022 12:45:41
Houdini gamboler
Grendizer
Right, but the ramp will give you a monochrome version of the base color. (well the red channel will be mapped to a color in the ramp) If you want the base color, but darker, consider applying gamma or scale.
OK, got it! I'm now using a mtlxrange node instead of the MTLX ramp node. Thanks again Jsmack.
Houdini gamboler
