3D Connextion space mouse with Houdini
   17177   24   2
a5af
You can think of the SpaceMouse not like a mouse, not like a game controller, but exactly like 1970's-era NASA docking controller on a space shuttle.
The control is:
Nonlinear,
Sensitive,
Counterintuitive, at first.
But real astronauts train to dock a module — where a wrong nudge means catastrophic failure.
The trick is not to fight it, but to reprogram your instincts.
You will start anticipating unnatural movement, strange drift, the backward lag, and the disorganized momentum — until your brain adapts, until the movement becomes second nature.
It must become second nature — because when you're controlling a spaceship (or a 3D object in Houdini), hesitation or overcorrection is not an option.
Master the drift. Master the tilt. Or crash and burn.
I thought I'd contribute my work to this effort.
Attempts So Far — 3Dconnexion SpaceMouse → Houdini Integration (with Tilt Correction)
1. Basic SpaceMouse → Houdini Setup
Installed 3Dconnexion drivers.
Confirmed SpaceMouse works outside Houdini (in viewer mode, etc.).
Houdini does recognize 3D input, but by default it’s camera-only — not tied to scene objects.
2. Custom Python Panel / Script Approach
Wrote custom hou.session or panel Python to hook into SpaceMouse input.
Problem: spacenavigator module dependency failed — not native to Houdini's shipped Python.
Tried pip installs inside Houdini — Python incompatibility (spacenavigator not available or crashes Houdini Python).
3. HID (Human Interface Device) Layer Attempt
Tried low-level raw HID access.
Success reading input outside Houdini, but no bridge between raw input and Houdini’s viewport transformations.
Writing a full input device driver → too much overhead unless embedding into the viewport.
4. 3Dconnexion SDK Direct Integration
Tried using 3Dconnexion SDK.
Problem: SDK is C++, not Houdini Python-friendly.
Need custom C++ plugin compiled against Houdini API — basically writing a custom OP, impractical for now.
5. Matrix Math Tilt Correction
Attempted to apply tilt correction:
Read rotation matrices.
Tried to extract "up" vector and re-orient.
Problem: Houdini's Matrix3 class missing methods like getRow3, extractRow (non-existent).
Correct tilt math needs more low-level matrix operations not exposed in Houdini's Python API.
6. Use of Default Houdini "Lock Horizon"
Tested Lock Horizon mode inside Houdini viewport.
Outcome: Partially corrects tilt, but not reliable in extreme rotations.
7. Fallback to 3Dconnexion System Settings
Modified global SpaceMouse settings (e.g., lock axes, lower sensitivity).
Better control overall — but still no native scene manipulation inside Houdini objects.
Next Possible Moves
Option 1: Custom C++ Houdini Plugin
Write C++ plugin using Houdini HDK.
Map SpaceMouse input directly to object transforms (NOT viewport camera).
Cost: Huge. Need to build and maintain.
Option 2: Use Intermediary Software
Use something like TouchDesigner, Blender, or custom app that reads SpaceMouse and sends data to Houdini via:
OSC (Open Sound Control) messages.
TCP/IP or websockets.
Houdini reads live input stream and transforms objects accordingly.
Option 3: Python PyWin32 Hook (Windows Only)
Poll for SpaceMouse via PyWin32 raw input stream.
Map to Houdini objects manually.
Option 4: Surrender to the Camera, Not Objects
Fully embrace controlling only the camera.
Build rigs or scripts to align view-based interaction to object placement after motion.
My god, sir! Did you write this with ChatGPT?!
Alright, I've been messing around with trying to get this to work for a while now.
I've finally managed to sort it out.
I'm using the Wireless Pro BT version
So I had to add the following python code to the python panel supplied by Jonothan (Thanks very much for giving us access to this by the way, it's amazing.)
After adding it the important part is getting the hid_id to be the same as your device.
You can check this by running and replacing the code below in your houdini python shell and replace hid_id= with your space mouse hid_id
Code to run in Python Shell
from pywinusb import hid
for d in hid.find_all_hid_devices():
    print(hex(d.vendor_id), hex(d.product_id), d.product_name)
CODE to ADD
"SpaceMouse Pro Wireless BT": DeviceSpec(
            name="SpaceMouse Pro Wireless BT",
            hid_id=[0x256F, 0xC638],          # BT product id
            led_id=[0x8, 0x4B],
            mappings={
                "x":     AxisSpec(channel=1, byte1=1,  byte2=2,  scale=-1),
                "y":     AxisSpec(channel=1, byte1=3,  byte2=4,  scale=1),
                "z":     AxisSpec(channel=1, byte1=5,  byte2=6,  scale=1),
                "pitch": AxisSpec(channel=1, byte1=7,  byte2=8,  scale=1),
                "roll":  AxisSpec(channel=1, byte1=9,  byte2=10, scale=1),
                "yaw":   AxisSpec(channel=1, byte1=11, byte2=12, scale=-1),
              button_mapping=[
                ButtonSpec(channel=3, byte=1, bit=0),   # MENU
                ButtonSpec(channel=3, byte=3, bit=7),   # ALT
                ButtonSpec(channel=3, byte=4, bit=1),   # CTRL
                ButtonSpec(channel=3, byte=4, bit=0),   # SHIFT
                ButtonSpec(channel=3, byte=3, bit=6),   # ESC
                ButtonSpec(channel=3, byte=2, bit=4),   # 1
                ButtonSpec(channel=3, byte=2, bit=5),   # 2
                ButtonSpec(channel=3, byte=2, bit=6),   # 3
                ButtonSpec(channel=3, byte=2, bit=7),   # 4
                ButtonSpec(channel=3, byte=2, bit=0),   # ROLL CLOCKWISE
                ButtonSpec(channel=3, byte=1, bit=2),   # TOP
                ButtonSpec(channel=3, byte=4, bit=2),   # ROTATION
                ButtonSpec(channel=3, byte=1, bit=5),   # FRONT
                ButtonSpec(channel=3, byte=1, bit=4),   # REAR
                ButtonSpec(channel=3, byte=1, bit=1),   # FIT
            axis_scale=350.0,
I hope this works for you guys.
Cheers.
Sorry to ask this here:
However, I would love to use a space mouse, as I find navigating 3D viewports with it quite enjoyable.
BUT you constantly need to switch between the hand on the keyboard and the hand on the Space mouse. This makes it useless in my experience. Even the model with the most buttons on whimpers compared to the number of keys on a keyboard. let alone entering values, names, etc...
So how do space mouse users deal with that?
If it's constantly switching between the Space Mouse and keyboard, I think it is not speeding up work but actually slowing it down.
Once again, I would love to use it...
Cheers
CYTE
With a little (okay, a lot of) help from ChatGPT, I was able to come up with this. Fixes the problem for me 100%. Makes the viewport work like normal ones. Hope this can help others.
https://github.com/Kienan-the-Barbarian/houdini-turntable-lock.git [github.com]
Thank you so much @K42
Works so much better like that. Bit annoying that there's still this jittering or "fighting" stuttering when the horizon is being rectified but nontheless miles better than before!
