How to set up a tangent direction angular constraint?
1186 1 0-
- chengnanliu95
- 1 posts
I'm doing scales sim for animated snake.I'm using constraint to make scales follow the body and solve collisions. My scales are packed RBD, i have a position constraint to lock the scales to snake body, which work fine. And i need to set up another rotation constraint, which controls the scales to only rotate in one direction. I tried Spring Constraint Relationship, it seems no where to set up the angle? By default it lock the rotation to initial state.
- tamte
- 9416 posts
usually by setting various attributes on your constraint geo
here is the full list https://www.sidefx.com/docs/houdini/nodes/dop/constraintnetwork.html#attributes [www.sidefx.com]
the ones you may want (on top of the usual ones) are p@orient, v@condof, v@condir
