COP Combine two images reordering their channels.
   3018   2   1
Hello everyone!
I've been learning Houdini for the past weeks and I wanted to ask something about the COP network.
Basically I would like to combine two images and select which channels go through to the result allowing me to reorder the channels of the inputs. I used Touch Designer quite a lot and they have a really handy operator that is called 'Reorder'. This OP allows you to do exactly that operation and I wanted to know if there is a way to do the same in the COP Network in Houdini.
I attached an example of how this 'Reorder' OP works in TD to show my desired result:
It inputs two images, input1_RBG and input2_RGB. Then I select that I want to keep the RGB channels from input1 and use the R channel from input2 as the new alpha. This creates an output that is RGBA. I hope the image can illustrate what I am referring to.
Thanks a lot!
Sebi
Edited by eusebijucgla - Aug. 10, 2022 15:14:04
Best,
Sebi
You're looking for the "Channel Copy" composite node. It works similarly to your example.
jsmack
Thanks! "Channel Copy" was what I was looking for.
For anyone wondering how to use it, I attach an image with the solution in Houdini.
Edited by eusebijucgla - Aug. 10, 2022 15:13:44
COP channelcopy.jpg (167.4 KB)
Best,
Sebi
