Karma "Ray Bias" viewport default
   1936   0   0
Is there is a way to modify the default Karma "ray bias" shading parameter for the default viewport settings (?)
I don't see it on "Display Options" but wondering if there is a ENV var that can be used for this?
I'm aware I can drop a "Karma Render Settings" and use those settings on my viewport but I was wondering if I can change the defaults since, on my end, I'll be always working on a scale that requires changing the default value lower.
Thank you!
