In Karma, How do i get an ambient occlusion render pass?
   7886   10   2
Is it possible? I can't find anywhere. I don't need AO for Shader. I need it for global scene.
On the Karma Render Settings node, enable "Simplified Shading" to switch to a global ambient occlusion mode. Note that Display color still tints the scene, so you might need to block the attribute on the geometry to get a gray render if the attribute is present.
Edit:
It doesn't seem to enable AO for XPU though, instead it renders a simple version of the scene without shaders and headlight only.
Edited by jsmack - Oct. 29, 2022 17:36:16
jsmack
Edit:
Thank you. Yeah, it looks like it might work, but Karma defenetely needs more better way of AO
Better than checking a box?
jsmack
Yes. It is a super global and I need more control. For example, I need AO only between objects and a ground and not AO of self produced ground.
beka
jsmack
That sounds like you need to write a custom shader.
jsmack
beka
jsmack
This sound you should avoid write answer here.
Edited by papahh - May 23, 2024 09:43:44
jsmack
beka
jsmack
WOW, still an issue
Edited by vopsop - July 7, 2025 16:30:08
vopsop
jsmack
beka
jsmack
WOW, still an issue
This is in the changelog.
20.5.305
XPU: adds support for AO AOV
Edited by Heileif - July 8, 2025 09:14:21
have a look here and analyze the hda. This should be tweakable to do what you need.
https://senlegio.gumroad.com/l/ss_clay_material_override [senlegio.gumroad.com]
Edited by mrtn - July 8, 2025 11:30:40
Heileif
vopsop
jsmack
beka
jsmack
WOW, still an issue
20.5.305
There is AO AOV now but zero control. Falloff, distance.... anything. Any ideas if we can do any control with that at all?
