Today, I finally wanted to take a look at the fabric samples. ( https://www.sidefx.com/contentlibrary/fabric-samples/ [www.sidefx.com] )
However, when highlighting the vellum solver and hitting play, ( I assume the same goes for the other ones, but I only tested the silk and the jersey), Houdini crashes every time, without showing any process being calculated in the bottom left of the window.
Can someone explain to me what the reason might be?
Am I overlooking something that needs to be cached first?
The file is for H18.5
I tried only tried it with H19 and 19.5, both py3 builds.
If someone from the SideFX team sees this could you maybe try to reproduce this, so I know if it on my end or not?
Or should I install 18.5?
In the past when opening old scene files, there seemed to be great backwards compatibility..
Thanks in advance.
Fabric samples
3056 6 1-
- cheesetroyer
- 53 posts
- Enivob
- 2658 posts
I just tried it using H19.5 and it worked for me. Consult the Support menu above and check the System Requirements. Perhaps your hardware does meet the specs?
I have seen multiple posts about OpenCL failures because of nVidia driver issues. You may want to check your driver version and see if there are any noted problems with it. I'm running 512.77.
Edited by Enivob - Nov. 2, 2022 10:00:37
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- cheesetroyer
- 53 posts
Enivob
Thank you for your response!
Hmm, hardware should be good, GPU is a RTX 3000 series, 64GB DDR4 RAM, B550 Motherboard.
Other HIP files open well usually.
I will see if Nvidia driver update fixes it, though I updated them just a few days ago.
I am running 526.47, alright, I'll check if this version causes issues. Do you know a good site for that?
Doing a quick search the first results show this driver version is lling issues in a certain game title, but I doubt that translates to Houdini..?
May I ask which Houdini build you are on? I am on 19.5.303 Py3.9
- Hatchery
- 141 posts
I think you've just had the same issue i had - https://www.sidefx.com/forum/topic/87162/ [www.sidefx.com]
Love Houdini
- cheesetroyer
- 53 posts
Hatchery
Hey, thanks for your reply.
Just to make sure:
- Staff was suggesting this was fixed in 19.5.408
- Underneath you were suggesting to downgrade the Nvidia driver..
Which one are you suggesting I follow?
I guess I will try it with 19.5.408 first, but just in case it doesn't work, which Nvidia driver version did you downgrade to?
Cheers
- Hatchery
- 141 posts
- cheesetroyer
- 53 posts
