A redshift install for Houdini 19.5 on Apple Silicon
   5046   3   0
I'm having trouble getting redshift to be recognised in 19.5 installs on my M1 mac. The usual .env installation method doesn't seem to work.
I've tried downloading from https://redshift.maxon.net/topic/31230/houdini-solaris-plugins-custom-builds [redshift.maxon.net]
I've tried to pair up a x86 install of 19.5.386 with the redshift (Houdini/Solaris 19.5.303/368/403 plugins for Redshift 3.5.10) which doesn't seem to work either.
Is there some compatibility issue between using rosetta houdini and a M1 configured redshift install?
I figured it out. The packages method seems to work. If anyone is interested.
hi there @tomotron.
can you highlight where you setup your package folder. having bigger difficulties here than i should be to be honest!
You can install your package file in $HOUDINI_USER_PREF_DIR/packages
E.g. redshift package for windows
    "env":[
        {"RS_PLUGIN_VERSION" : "${HOUDINI_VERSION}"},
        {"REDSHIFT_COREDATAPATH": "C:/ProgramData/Redshift"},
        {"HOUDINI_PATH": "${REDSHIFT_COREDATAPATH}/Plugins/Houdini/${HOUDINI_VERSION}"},
        {"PATH": "${REDSHIFT_COREDATAPATH}/Redshift/bin"},
        {"PXR_PLUGINPATH_NAME" : "${REDSHIFT_COREDATAPATH}/Plugins/Solaris/${RS_PLUGIN_VERSION}"}
