problem with redshift proxy export
   7666   5   1
Hello!
i'm learning grooming with Houdini and i've a problem for the redshift proxy export.
I'm trying to export my main fur for the test a render in maya/redshift but when i'm try to export with the redshift proxy output the file which was exported is empty or 7ko.
Who know's where is my error?
Best regard,
Where you able to figure this out? running into same problem here.
Enrique De la Garza
CG Supervisor @Frame48
Having a similar issue. But I was able to write proxy files that worked. Later I went back and changed a texture on the material and exported the same proxies again. This time it wrote empty files. Still trying to figure it out but everything I try only writes empty proxies now.
Will post back here if I find a reason for it.
Hi!
You should try to post an basic repro file on the Redshift forum to see if Juanjo can find the problem:
https://redshift.maxon.net/category/26/bugs-houdini [redshift.maxon.net]
Cheers!
The node you're using to export the proxy needs to have it's display flag on. I've run into this before.
Andi Farhall
Thank you!!!!!
