Hey guys, creating glue constraints dynamically is pretty straight forward, but it looks like creating hard constraints isn't.
if I drop an object, then create a hard constraint when it hits the ground, with both points on each other, one with an empty name (to pin to the world), with a restlength of 0, it looks like adding a hard constraint sends the object back to its initial position and orientation, as if the constraint had been created in the source. I can't make sense of this because both points of the constraints are where the hit was. looking at the distance and angle attributes, they have values that correspond to the difference between that hit position and the rest, so then the constraint sends it back to the rest to satisfy the distance and angle to be 0, even though both points of the constraint are away, down on the ground! The only explanation I can think of is that the hard constraint just lerps between current and rest packed full transforms and doesn't care about the position of the anchor, although that doesn't make sense either since the position of the anchor defines the pivot of rotation for a constraint type position.
So I'm confused!
So besides an explanation on this that would be great, is it even possible to make hard constraints dynamically?
cheers
Louis
bullet dynamic constraints
2515 6 0-
- manja_CGMA
- 7 posts
- tamte
- 9384 posts
- manja_CGMA
- 7 posts
- tamte
- 9384 posts
manja_CGMAconstraints can use p@orient attribute on anchors, again, in rest space of the piece (which in most cases is world space at initial frame)
hey, thanks.
how about the angle? there's no info of orientation on constraints.
alternatively you can use v@r
https://www.sidefx.com/docs/houdini/nodes/dop/constraintnetwork.html#anchor-attributes [www.sidefx.com]
- manja_CGMA
- 7 posts
- manja_CGMA
- 7 posts
- manja_CGMA
- 7 posts
