Vex Connect two points with a line
   3643   2   0
Hello
I have a problem, I don't understand why I can't connect two points to create a line with vex (ofc it works if i use "add" sop, but i want to use vex) ?
This is my vex :
int points[];
vector max = detail(1,"max");
vector zpos = set(0,0,max.z);
addpoint(0,0);
addpoint(0,zpos);
addprim(geoself(), "polyline", points);
Your points array is empty. You have to populate it with the new point numbers or just pass them directly to addprim:
int points[];
int pt0 = addpoint(0,0);
int pt1 = addpoint(0,zpos);
addprim(geoself(), "polyline", pt0, pt1);
Thank you very much
