Scene Graph Tree selection with Python
   4112   9   2
Is it possible to get/set selection for the Scene Graph Tree in Python. I was looking at the docs and could not find anything.
https://www.sidefx.com/docs/houdini/hom/hou/SceneGraphTree.html [www.sidefx.com]
The scene graph tree shows the selection owned by the LOP Network. You can get or set that selection using hou.LopNetwork methods (selection() and setSelection()).
Thank you mtucker! That was it. I was looking in the wrong place.
I have a follow up question.
Is there a selection change callback for the custom Panel editors?
Thanks.
Yep, you can use `hou.node('/stage').addEventCallback(, cb_function)`
Which event type that would be? I tried SelectionChanged but it's not firing up.
Zhuk Cmon
It should be that. If you paste this in the Python pane and then click in the scenegraph tree you should see messages appearing.
hou.node('/stage').addEventCallback([hou.nodeEventType.SelectionChanged,], lambda node, event_type: print('Selection changed!'))
This of course assumes the lopnet you want to watch is indeed /stageand not, for example, /obj/lopnet1.
Edited by robp_sidefx - April 14, 2023 05:07:43
Gotcha, yes this works. I was registering callback for particular lop node not network.
Thank you.
robp_sidefx
Zhuk Cmon
Hi,How to get the current selected prims in Scenegraphtree pane, why dont Houdini pass the selected prims to kwargs of the callback funtion?
Edited by jerrykyj.kon - Nov. 27, 2023 17:04:36
We didn't bother to add that to the kwargs directly because it's information that is easy to get from the node:
kwargs['node'].selection()
