we are having trouble displacing the ocean until the horizon.
is there any other setting that could help fix this issue and is there a way to somehow visualize the dicing? like a utility shader or an AOV that could help troubleshoot?
we noticed the dicing flatness setting in the docs but it seems to be missing on the lop nodes, creating it manually did not seem to change the result.
we also tried the different dicing checkboxes on the oceansurface shader, which did not seem to change the result.
thanks.
Karma Ocean Dicing
3801 6 1-
- spektra
- 29 posts
- tamte
- 9417 posts
- jsmack
- 8184 posts
- tamte
- 9417 posts
- jsmack
- 8184 posts
- spektra
- 29 posts
tamte
I wonder if Karma supports automatic Displacement to Bump and Bump to Roughness conversions based on the pixel coverage or some screen space metrics
based on the tooltip on the oceansurface shader im guessing thats what the "Add Bump to Ray Traced Displacements" should do (unfortunately we have not used mantra).
If it turns out that its not possible in one render in Karma i would still be curious if there's a way to convert the Ocean Sample Layers output to a bump/normal input to check if the results of that could be blended successfully in comp.
- dlee
- 478 posts
Hi. With the latest daily build (19.5.509 or newer), you can set environment variable KARMA_DICING_LEGACY to 0 to switch to newer dicing code that will help with visible discontinuity seen in the original post.
But no, karma currently does not support bump to roughness or displacement to bump (ala mantra).
