Cloth going through the Mesh ?
2900 5 1-
- _Christopher_
- 767 posts
- tamte
- 9384 posts
it depends on whats causing the interpenetration, more info may be needed
but it feels pretty forced, so if it's caused by a collider or strong pin, then there is not much Vellum can do to prevent it, you just should be aware of not forcing it into such situations and maybe use different approach that gives Vellum a chance to converge
- made-by-geoff
- 84 posts
Posting a hip file would help, but you can tell from the jittering all along the bottom of your mesh that vellum is fighting against itself. That type of jittering is usually caused by settings that are "un-convergeable". For instance, if you set your bend and compression stiffness too high and then try to get a piece of cloth to fall to the floor in a heap, you may get that kind of jittering because the cloth wants to compress into a smaller space, but you've given it a high bend and compression stiffness that is preventing that from happening. The result is jitter.
If I had to guess, I'd say there is something wrong with your invisible collider that is causing both the jitter and the inter-penetration of the top of the cloth. But hard to tell from just a screen capture.
- _Christopher_
- 767 posts
- made-by-geoff
- 84 posts
Mesh resolution, bend stiffness, and compression stiffness are the main parameters that affect how cloth behaves. Stretch stiffness also makes a difference, but less so that the others for typical fabrics like cotton, denim, leather, etc. If you are trying to simulate stretchy fabric, of course, it's a different story.
More recent versions of vellum do a better job working independently of mesh resolution. A medium resolution mesh should behave "similarly" to high resolution meshes, but will lack finer detail and wrinkling. But mesh resolution will definitely create an upper limit on how detailed your wrinkles can get.
This is a good starting point for understanding how different settings affect the look of different types of fabric:
https://www.sidefx.com/tutorials/h17-vellum-cloth-lookdev-tips/ [www.sidefx.com]
- _Christopher_
- 767 posts
made-by-geoff
Thanks, the link explains some of the parameters in short.
【T】【C】【S】
