Control DOF of camera?
2752 3 1-
- litote
- 269 posts
- mrCatfish
- 738 posts
- litote
- 269 posts
- jsmack
- 8177 posts
litote
Thanks, the F-Stop is the same as moving the cones on the widget. Not quite what I meant. I want to increase the blur without moving this, which acts like a region of focus. If you adjust F-Stop it also changes the region of focus.
No, that's not possible. Changing the depth of field continuously changes the region in focus. In reality, the depth of focus is always 0. The cones are there to illustrate where the area likely to be perceived as in focus is located. F-stop is the only control for this.
Edit:
Performing depth of field blur in post using compositing software is an option that would allow for non-physical behavior that you describe.
Edited by jsmack - March 1, 2023 19:10:03
