unlinked cops viewers?
   5391   3   3
Is it possible to quickly view two separate COPs
nodes on two separate viewers? In Houdini 4.1
you could do this via a dropdown in each viewer
but that seems to be missing now.
What I'm trying to do is edit a rotospline in one view
while seeing the end result (last node) in another.
-cpb
Shift click on the disply flags for each COP you want to view.
okay thanks, I'll race home and try it.
-cpb
ok that sort of works but what if I want to:
view the rgb of a node in one viewer and the alpha in another,
view one node at 1/4 rez while viewing another at full,
view one node on a small viewer while viewing another on a large viewer,
view handles and info on one viewer while leaving another clean.
and so on…
also the new rows and columns system is very temperamental;
it will occasionally hang the program if the same node is dragged into
different cells, or if multiple nodes are dragged in. It will also
do an ugly, worse-than-anything refresh whenever a toolbar is expanded.
The H4.1 system of multiple viewers is practical and clean. Is there
any way to bring it back?
-cpb
