problems with local licensing server. RHEL9
   6137   5   1
Hello, I've been using sidefx as my licensing server to avoid issues with my licensing server.
Because of security issues, I’ve decided to switch to using a local server.
this brings me back to being stuck.
I these are some errors i got when trying to troubleshoot this.
❯/etc/init.d/sesinetd stop
zsh: no such file or directory: /etc/init.d/sesinetd
❯ sesictrl print-server
http://localhost.localdomain:1715: No server found running. Please start the server before retrying.The next generation checkout system is currently being used. Please make sure all components of licensing (i.e. hserver, sesinetd, etc) support this system.
----- SERVER www.sidefx.com --------
SERVER www.sidefx.com 0051def8
sesinetd: Version 19.5.10917
IP Address: 206.223.178.163
Enabled Https: true
Read Mask: *.*.*.*
Write Mask: +.+.+.+
ERROR: You do not have read access to server localhost.localdomain
Annyone able to help me troubleshoot this ?
Thanks in advance !
ok so if click the gear next to the license server and pres details it tells u sesinetd is at /usr/lib/sesi
Trying to run sesinetd renders me this error
❯ sudo ./sesinetd
id: ‘www-data’: no such user
chgrp: cannot access '/usr/lib/sesi/licenses': No such file or directory
chown: cannot access '/usr/lib/sesi/licenses': No such file or directory
and trying to enable the sesinetd.service gives me this error
❯ sudo systemctl enable sesinetd.service
sesinetd.service is not a native service, redirecting to systemd-sysv-install.
Executing: /usr/lib/systemd/systemd-sysv-install enable sesinetd
Failed to execute /usr/lib/systemd/systemd-sysv-install: No such file or directory
Edited by nicolaas.tanghe - March 30, 2023 13:28:36
How did you install Houdini and the license server?
For the systemctl failure, try installing the chkconfig package and try again.
I installed via the launcher.
In the meantime, I reinstalled the license server (because I had changed my hostname it didn`t find the server)
I am stil getting the error:
(plz make all the text in errors selectable in future versions)
Here is the output.
❯ sudo ./sesictrl diagnostic
Diagnostic Output:
If you are having licensing problems, please save this information and email it
to support@sidefx.com.
License Administrator output:
Generated on:                           Fri Mar 31 12:30:43 2023
Local host name:                        RHEL-FX-workstation-01
Local server code:                      5b388504
Local ip address:                       127.0.0.1
System:                                 "Red Hat Enterprise Linux" (linux-x86_64-gcc9.3)
Number of servers:                      1
License server name:                    http://localhost.localdomain:1715 (RHEL-FX-workstation-01)
   License server server code:          5b388504
   Server ip address:                   127.0.0.1
   Reported host name:                  RHEL-FX-workstation-01
   Reported host ip address:            fe80::eeef:30a0:3167:7e03
   License server is running:           Yes
   May read licenses from server:       Yes
   Has SERVER license:                  Yes
   License server version:              19.5.571
   May modify server from this machine: Yes
   Redundant Configuration Enabled:     Yes
License Administrator version:          19.5.571
Http NoProxy:                           localhost,127.0.0.1
Http Proxy:                               (none)
Can retrieve https://www.sidefx.com/api/license/: Yes
Using API Keys:                         No
Can Manage Licenses:                    Yes
Login Based Account:                    Yes
Logged In:                              Yes
Scrub User Names:                       No
Available Entitlements:
 - E-744614 "Rental" "Houdini Indie" 2 +.+.+.+ 16-sep-2024
 - E-744615 "Rental" "Mantra (Indie/Education/Apprentice)" 2 +.+.+.+ 16-sep-2024
 - E-744616 "Rental" "Karma (Indie/Education/Apprentice)" 2 +.+.+.+ 16-sep-2024
Installed licenses:
    LicID    Platform   Product                        Ver Avail Expiry
sesictrl print-license output:
----- SERVER http://localhost.localdomain:1715 --------
hserver -l output:
Hostname:	RHEL-FX-workstation-01	["Red Hat Enterprise Linux"]
Uptime:		0:07:57	[Started: Fri Mar 31 12:22:46 2023]
License Server:	http://localhost.localdomain:1715
Connected To:	http://localhost.localdomain:1715
Server Version:	sesinetd19.5.571
Version:	Houdini19.5.569
ReadAccess (Ipv4):
WriteAccess (Ipv4):
ReadAccess (Ipv6):
WriteAccess (Ipv6):
Forced Http: false
Enabled IPv6: false
Used Licenses: None
    22,676 of 31,747 MB available
    CPU Usage:1% load
    0 active tasks (32 slots)
HTTP(s) Backend Info:
library:                     libcurl/7.79.1 (x86_64-pc-linux-gnu)
SSL Version:                 OpenSSL/1.1.1b
Features:                    AsyncDNS HTTPS-proxy IPv6
licenses file:
* Could not open the licenses file. *
Edited by nicolaas.tanghe - March 31, 2023 06:35:19
Screenshot from 2023-03-31 12-33-51.png (6.6 KB)
Ok so my problems were fixed by manually browsing to
and then putting 3 licenses in there via the web interface.
Doing this added an entry to my server list which is called
this error remained.
It was fixed by running :
sudo dnf install chkconfig -y
Edited by nicolaas.tanghe - April 1, 2023 14:58:22
