UVs to UDIMs via scale and cut around UDIMS
1028 0 0-
- tadian
- 92 posts
Was wondering if there is a more efficient way to do what I'm trying. I've created a file(see attached) that allows you to scale up your uvs across multiple UDIMS. The file will then cut whatever is in that UDIM and separate it from the surrounding UDIMs. It works ok. However, this does start to chug a bit on higher topology. Was wondering if there's any other ways to do this?
