I have fed some geometry with a Material (texture map) in to a Copy node and then checked Pack and instance.
This stops the material from being renderable. Is there a way to retain the packed state and still render the Material on the geometry?
How to keep a Material on packed geometry?
1967 4 1-
- litote
- 269 posts
- Enivob
- 2658 posts
- litote
- 269 posts
I am using Mantra (Houdini v18.5). It does not render a Material if I use a Duplicate node or a Copy to Points node and check "pack and instance".
I found the issue: In Mantra ROP you must set Rendering tab-Render tab-Declare Materials: Save All Materials and Shaders
Edited by litote - June 27, 2023 00:45:50
- tamte
- 9380 posts
- litote
- 269 posts
