Random color from a defined color range
   5852   2   0
Hi, everyone!
The question is: there's a shader, it has one main solid color that is to be mixed with another. That “another” color should be a random one, but taken from a certain color range, for example, from 128, 15, 36 - 128, 15, 56.
Is there any way to do it?
Thanks.
Mix these two border colors with mix Color VOP using random number as a bias value.
Remember that you have also HSV_to_RGB and RGB_to_HSV VOPs, so you can control only hue value of your colors if mixing three rgb channel it's not what you want.
hope this help.
sy.
Thanks, SYmek! I'll give it a try.
