Generics/Templates in Vex
   2003   6   2
Hi!
I have this Vex code:
float get_value_from_list(float list[]; int start_offset, int absolute_index) {
    int local_index = absolute_index - start_offset;
    return list[max(0, min(local_index, len(list) - 1))];
What if I want to make it so that my code works regardless of the datatype of the array? In C++, I know there's "templates" which allow you to write code that works with different data types without having to duplicate the implementation, e.g.
template <typename T>
T get_value_from_list(T list[], int start_offset, int absolute_index) {
    return list[max(0, min(local_index, sizeof(list) / sizeof(T) - 1))];
Can anything like this be done in Vex?
Anson
Sort of, you can use pre-processor #define() directive to do something similar
For example you can have a look at $HFS/houdini/vex/include/subdcurve.h
Nice! Works great! For anyone else, this is what I had to switch my code to:
#define GENERIC_MACRO(TYPE) \
TYPE get_value_from_list(TYPE list[]; int start_offset, absolute_index) { \
    int local_index = absolute_index - start_offset; \
    return list[max(0, min(local_index, len(list) - 1))]; \
// Apparently this blank line is important
GENERIC_MACRO(float)
GENERIC_MACRO(vector)
// etc, for all types you want to support.
#undef GENERIC_MACRO
Thanks again!
Anson
Edited by AnsonSavage - Aug. 10, 2023 14:38:29
I have an RFE for generics in VEX. So if you want to see this feature, feel free to bump it up: RFE #59282.
animatrix_
RFE #59282
I'd love to! I'm kind of new to this, where do I access that RFE? I couldn't figure it out.
Thanks,
Anson
AnsonSavage
animatrix_
RFE #59282
Thanks,
Anson
I don't think you can, I believe BUGs and RFEs are tied to an account so only profiles associated with that account can access them
which makes sense from the point of view that a lot of BUG/RFE reports can contain sensitive information
but you can always submit your own RFE and I believe they are being bundled together if they overlap
AnsonSavage
animatrix_
RFE #59282
Thanks,
Anson
You just have to create a new report and mention my RFE ID so they can link them.
