sample_direction_cone but on the maxangle instead of within?
   1413   3   1
I have a vector X, and I'd like to randomly generate a vector Y so that the angle between X and Y is 60 degrees.
There is a VEX function sample_direction_cone that can generate a vector Y so that the angle between X and Y is no more than maxangle degrees.
But that's not what I need. I need the angle between X and Y to be exactly 60 degrees, not <= 60 degrees. How could I do that?
one of the ways
vector dir = {0,1,0};
float angle = radians(60);
vector rdir = sample_direction_cone(dir, PI/2, rand(@ptnum));
vector4 rot = quaternion(angle, normalize(cross(dir, rdir)));
v@N = qrotate(rot, dir);
Here is one way using matrices:
vector dir = @N;
float angle = radians ( ch("angle") );
float u = rand ( i + @ptnum * ( i + 14.2351 ) );
vector axis = sample_direction_cone ( dir, PI, u );
vector pdir = normalize ( cross ( dir, axis ) );
matrix M = ident ( );
rotate ( M, angle, pdir );
vector rdir = dir * M;
You people are VEX gods :o
