Milling process with smooth surface
   1379   1   2
Hi
I want to create a milling process but with smooth surface. I've attached an example (HIP File) of what I am trying to do.
In a real milling process you wouldn't see those steps (red & green) and the surface would be smooth.
How can I achieve this?
cheers
Edited by BAlmighty - Sept. 19, 2023 18:43:17
milling_process.hiplc (158.3 KB)
Screenshot 2023-09-20 003305.png (346.8 KB)
in real milling process you'll get the same type or defects because of the feed speed. In your case solutions are:
- increase substeps in the solver1 and this gives you smooth vertical surface;
- animation in the transform1 should be much longer in time then animation in a tube sop. This will allow you to get smooth horizontal surface.
