is there a way to only preserve specific edges while resampling with the “Resample by polygon edge” activated? I have some grid with x cols and the x points between two of the edges are translated by a point-sop. Later I want to use this geometry to make a fence surrounding it, but I want the different parts of the fence to have the same, fixed length. I tried to resample the geometry without preserving the edges, but that destroys the two 90 degrees edges. When “Resample by polygon edge” is activated, all points of the geometry are preseved, and that's what I neither want. Only the four points 0, 18, 19, 37 should be preserved. Hope someone has an idead.
thanks
Problem with resample by edge
11534 6 3-
- Peacemaker2000
- 11 posts
- Pagefan
- 519 posts
- Peacemaker2000
- 11 posts
- JColdrick
- 4140 posts
- Antoine Durr
- 321 posts
JColdrickYes, make the corner points unique (with the facet SOP), then do the resample, then do a join SOP (not 100% sure if that will work), or an add SOP where you first delete all geometry and then just make a poly that's points 0-999999.
Just off the top of my head, I'd probably approach this by dealing with the two resampled edges as separate, unconnected curves, do whatever I'm doing to them, then connect them as one.
J.C.
– Antoine
- old_school
- 2540 posts
Treat each edge as a separate segment.
Check out my fence builder blog:
http://www.sidefx.com/index.php?option=com_content&task=view&id=688&Itemid=216 [sidefx.com]
- Peacemaker2000
- 11 posts
