Access blend shapes using apex
3403 5 2-
- johnlilpy
- 52 posts
- william_harley
- 107 posts
I have yes, have a look at the content library.In the lucha and chicken demo file Im using blendshapes to drive the face joints on both characters. Its a little more complicated in that it computes the local transform on the joints and sets the blend on the skeleton , but you could edit it to work for normal blendshapes.
- william_harley
- 107 posts
- johnlilpy
- 52 posts
william_harley
Thanks for the reply. If I understand the rig correctly, the blend shapes are applied to the joints as opposed to the mesh. It would be fantastic to include examples/apex rig components to show us how to add blend shapes and corrective blend shapes for the meshes.
william_harleyReally looking forward to it!
Will add an example to the content library soon.
- legw
- 7 posts
- william_harley
- 107 posts
Hi, sorry for the delayed reply.
I have included normal mesh based blendshapes in the pillow example file.
here: https://www.sidefx.com/contentlibrary/apex-pillow/ [www.sidefx.com]
Corrective blendshapes will take more setup time at the moment, but essentially you would be using
the Transform Objects parameter values to drive the blendshapes. so instead of using an abstract control, you can fit and clamp
the values from say, the rotation of a joint to drive a corrective.
