In the new version, the default colors of nodes disappear.
2828 7 2-
- HGaal
- 102 posts
I install daily versions. And I see that the default colors I assigned for the nodes work in the old version, but disappear in the new one. And so every time. All other settings and menus remain. This means that this color file is not stored in the settings folder in documents. But does anyone know where?
- HGaal
- 102 posts
- AslakKS
- 292 posts
I assume you've reported this through the official channels? https://www.sidefx.com/forum/topic/25347/ [www.sidefx.com]
This seems like it should be an easy bug to fix
- HGaal
- 102 posts
Of course I reported this. But they don't consider it a mistake. That is, we need to stop this coloring and not get angry at every assembly. Color, shapes, drawn knots on the shelf. Everything disappears. But why then did they work and create these methods? I definitely don't understand something.....
- edward
- 8083 posts
I think it would make sense between 19.5 and 20.0 but it shouldn't matter between 20.0.XYZ versions. Perhaps you didn't explain this clearly enough in your bug report? I'd try again and make sure you include as much information as possible, including full steps to reproduce from a stock installation.
- raincole
- 694 posts
HGaal
Did SideFX support really say "we don't consider the node colors and shapes disappearing a mistake"? Press (X) to doubt.
As a side note, does anyone know where these colors and shapes settings are stored?
Edited by raincole - Nov. 25, 2023 17:40:57
- HGaal
- 102 posts
raincoleHGaal
Ahahaha, of course not. It’s just that when they mark it as a bug, they report it as a bug. When they don’t want to admit and fix the bug, then the classic thing begins -“reboot the router”, “reinstall Houdini, check the settings” and all that.
Edited by HGaal - Nov. 26, 2023 09:19:07
- edward
- 8083 posts
