HDA operator's default shape and color in Network View
   2185   5   1
Hi!
Where can I specify the Network View shape and color of a custom built HDA operator, so that it always has this as default shape on create?
Thank you!
Hold ctrl and drag the shape onto your node
But don't forget that installing a new build will destroy all custom node colors. Complain to support, maybe they will fix it someday. In a few years.
A good way to do this is by setting the shape and color in the HDA's OnCreated script.
kwargs["node"].setColor(hou.Color((1, 0.725, 0)))
kwargs["node"].setUserData('nodeshape', 'circle')
The list of available shapes can be accessed with hou.NetworkEditor.nodeShapes method.
ObeidaZakzak
Thanks! This is the way!
HGaal
There's nothing to be fixed.
When you change a nodes default color or shape Houdini saves out files respectively -
"Default_Theme_theme.nodecolors"
and
"Default_Theme_theme.nodeshapes"
They are saved in the same folder as your houdini.env file.
So all you have to do is copy those files and place them in your new install.
Nothing lost.
Edited by BabaJ - Dec. 7, 2023 13:24:48
