Looking through this page as I document an HDA:
https://www.sidefx.com/docs/houdini/help/format.html#icons [www.sidefx.com]
I have some buttons in my HDA that are represented only as icons, loaded from the standard set of icons (hicon:/) that ships with Houdini. I'd like to add these to the parameters description of my HDA's Help page, but I am struggling with the syntax. My wiki markup-fu is failing me. The page linked above shows examples of icons from other nodes (e.g. Icon:SOP/copy, but I'd like to pull my icon from the hicon:/ location instead.
Anyone know the syntax for that?
Display Icons in HDA Help Page
2891 4 2-
- Tim Crowson
- 250 posts
- Honza Topinka
- 12 posts
- animatrix_
- 5107 posts
I use this template for years:
= Attribute Gradient = #type: node #context: sop #internal: attribGradient #icon: opdef:.?icon64.svg """Computes the gradient of a scalar attribute using connectivity or proximity.""" @parameters Group: #id: group Subset of geometry to use. Group Type: #id: grouptype The type of entities in the group. Attribute: #id: attribute Name of the input attribute. New Attribute: #id: new Name of the new attribute that will store the gradient. Method: #id: method The method used to compute the gradient. Connectivity: Uses edge connectivity to compute the gradient. Point Cloud: Uses point proximity to compute the gradient. Neighbouring: #id: neighbouring The type of neighbouring to use. By Edges: Uses the edge neighbours of each point when gathering their point neighbours. By Primitives: Uses the primitive neighbours of each point when gathering their point neighbours. Depth: #id: depth Number of edges/primitives away from the points. Radius: #id: r The radius of the search. Max Points: #id: maxpts The maximum number of points queried within the search radius. Use Radius Attribute: #id: useradius Uses a per-point radius attribute. Radius Attribute: #id: radius Per-point radius attribute that expands the search radius. Radius Scale: #id: rscale Multiplier for the radius attribute. Invert: #id: invert Negates the direction of the gradient vector. Show Guide: #id: guide Shows the gradient vectors in the viewport. Guide Scale: #id: guidescale The scale of the guide geometry.
- Tim Crowson
- 250 posts
Honza Topinka
Hey.
Try this:[Smallicon:BUTTONS/cook]
I'm not sure where I got it from. I think I had to dig it up in the Houdini install.
Thanks! This did the trick... I almost had it, just had to replace the underscore with a slash...
[Smallicon:BUTTONS_cook]--> [Smallicon:BUTTONS/cook]
- Tim Crowson
Technical/CG Supervisor
- wyhinton1
- 95 posts
