Question : for each primitive in vex
2087 4 0-
- A-kun
- 8 posts
- jsmack
- 8177 posts
I'm not sure what you're after, but you don't need a for each loop block in sops just to enumerate primitives in VEX. On the wrangle, change the run over to primitive, and @primnum will be the number of the current primitive. The for each loop block is only needed for isolating parts of the geometry and running a set of nodes over each isolated part.
- A-kun
- 8 posts
- tamte
- 9380 posts
if your primitives are all separate you can do this in Point Wrangle
if any of the points is shared among multiple primitives it will get the vertex index value from first connected primitive
i@get = vertexprimindex(0, @vtxnum);
Edited by tamte - May 5, 2024 20:21:26
- animatrix_
- 5100 posts
A-kun
Hi I simply want to have the same pointNumber between distant primitives. so I used foreach node to run the wrangle to get the same numver between them but I feel this is not smart way so would like to do the same thing just in vex.
If you mean to get the same point indices between different prims, you can just create a new points array for each prim like so:
int indices [ ] = array ( ); int pts [ ] = primpoints ( 0, @primnum ); foreach ( int index; int pt; pts ) append ( indices, index ); i[]@indices = indices;
