Errors at Startup
   3827   9   5
Hi there,
while 5 20.5.278 starts normaly, every other daily build throws the folloing errors:
ite-packages-forced\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
return original_import(name, *args, **kwargs)
ModuleNotFoundError: No module named 'kinefx'
ERROR: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.307/packages/kinefx/viewer_states/sidefx_sop_capturelayerpaint-2.py
File "<stdin>", line 1, in <module>
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.307/houdini/python3.11libs\viewerstate\utils.py", line 967, in register_pystate
mod = importlib.import_module(module_name)
File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.307\python311\Lib\importlib\__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name, package, level)
File "<frozen importlib._bootstrap>", line 1204, in _gcd_import
File "<frozen importlib._bootstrap>", line 1176, in _find_and_load
File "<frozen importlib._bootstrap>", line 1147, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 690, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 940, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.307/packages/kinefx/viewer_states\sidefx_sop_capturelayerpaint-2.py", line 16, in <module>
import _kinefx
File "C:\Program Files\Side Effects Software\Houdini 20.5.307\python311\lib\site-packages-forced\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
ModuleNotFoundError: No module named '_kinefx'
ERROR: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.307/packages/kinefx/viewer_states/sidefx_sop_capturelayerpaint.py
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.307/packages/kinefx/viewer_states\sidefx_sop_capturelayerpaint.py", line 3, in <module>
from kinefx.attribwatcher import AttributeWatcher
ERROR: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.307/packages/apex/viewer_states/apexanimate.py
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.307/packages/apex/viewer_states\apexanimate.py", line 5, in <module>
import apex
ModuleNotFoundError: No module named 'apex'
ERROR: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.307/packages/apex/viewer_states/apexdebugstate.py
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.307/packages/apex/viewer_states\apexdebugstate.py", line 3, in <module>
import apex
ERROR: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.307/packages/apex/viewer_states/apexmapcharacter.py
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.307/packages/apex/viewer_states\apexmapcharacter.py", line 2, in <module>
import apex
ERROR: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.307/houdini/viewer_states/sidefx_polyhinge.py
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.307/houdini/viewer_states\sidefx_polyhinge.py", line 13, in <module>
from apex.xformgadgetutils import DragGuide
ERROR: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.307/houdini/viewer_states/sidefx_quickshapes.py
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.307/houdini/viewer_states\sidefx_quickshapes.py", line 14, in <module>
from apex.xformgadget import ApexXformHandle
ERROR: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.307/houdini/viewer_states/sidefx_quickshapes_lop.py
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.307/houdini/viewer_states\sidefx_quickshapes_lop.py", line 19, in <module>
Error running event handler:
File "kinefx::Sop/adapttoterrain, ViewerStateModule", line 3, in <module>
File "kinefx::Sop/adapttoterrain, opdef:/kinefx::Sop/adapttoterrain?ViewerStateInstall", line 1, in <module>
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.307/houdini/python3.11libs\viewerstate\utils.py", line 1007, in register_pystate_embedded
raise ViewerStateException(
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/kinefx::Sop/adapttoterrain?kinefx::Sop/adapttoterrain
File "labs::Lop/karma::2.0, ViewerStateModule", line 18, in <module>
ModuleNotFoundError: No module named 'ParseExrMetadata'
File "labs::Lop/karma::2.0, opdef:/labs::Lop/karma::2.0?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/labs::Lop/karma::2.0?labs::Lop/karma::2.0
Any ideas what is going on?
in build 307 everything is fine
Check whether one of the modules listed in the error message is actually available:
If so, check your protection history, maybe some parts of Houdini are blocked.
Also check if you install the right Houdini Python Build, if you run 3.10 then according to error massage it tries to import from 3.11.
20.5: No Module Named 'ParseExrMetadata' [www.sidefx.com]
No module named sidefx_stroke or kinefx.stateutils [www.sidefx.com]
Edited by vikus - July 26, 2024 08:39:04
Thanks for the input.
Its the right build. I also tried the workarounds in your loinks, but nothing seems to help.
It runs fine on my 2nd machine, though.
Maybe you've got some hardcoded paths to the older Houdini version in your preferences/packages. Try:
- Quit all Houdini sessions
- Find your "houdini20.5" directory under documents. Rename this.
- Start the new Houdini version.
If that is still having issues. Check your system/user environment variables for anything that has a Houdini build version in it.
Are you maybe running Octane? I've seen other people get lots of errors on launch when running dailies and having Octane active
Thanks for the suggestions.
Octane is indeed running, but disabling it - or renaming the houdini20.5 directory - doesnt affect the errors.
Its the dailiy builds, the produtciton build is running fine.
Maybe you renamed the wrong houdini20.5 directory? After doing this and starting Houdini, double-check that Octane is actually gone.
Another thing is that I'm not sure how you've set up things up. You can also try opening a Command Line Tools window running the the "hconfig" command to see if that looks correct (post your screenshot).
Thanks, now with the new Production build the errors reduced to just those two:
File "C:\Program Files\Side Effects Software\Houdini 20.5.332\python311\lib\site-packages-forced\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.332/houdini/python3.11libs\viewerstate\utils.py", line 1007, in register_pystate_embedded
There are workarounds for these, but they dont do their job for me.
Nevertheless, everything seems to work, those labs nodes? dont interfere.
Thanks everyone for their help!
I think this last error is a bug although I'm not sure if anyone should be using the karma lab nodes anymore. Please log a bug.
