SOP FLIP questions / issues
   1478   3   0
Hello everyone,
I'm working on a shot of a character swimming through a lake and a portal opens and blasts him with water.
So far everything is working ok but I do have two issues.
Issue #1: At lower particle separations my source seems to freak out at the top even though the entire source is well within the domain.
Issue #2: When sourcing via the SOP workflow, how do I jitter the particles per substep?
Please see attached video.
Any help would be greatly appreciated.
No artifacts show up when viewing the source prior to it going into the FLIP sim.
Edited by Dedrich - Aug. 2, 2024 14:02:27
mplay_zB5b0oweMG.mp4 (7.4 MB)
It seems that the emitter freaking out issue is resolved if I put the max substeps to 4.
The source particle jittering though is still a mystery.
Is there no way to jitter the source particles for the SOP FLIP workflow?
I'd assume they are already jittered randomly per substep
if you look into: flipsolver1/dopnet1/flipsolver1/gasseedfluidparticles1
which seems to be the node responsible for seeding particles within source volume
you should see that the Seed parameter already accounts for floating frame and therefore should be changing per substep
ch("../seed")+$FF
this is also linked to seed all the way at the Flip Solver SOP in Particle Behavior Tab/Reseeding/Random Seed so if you want to additionally vary the jitter seed you can also animate this one on top
Edited by tamte - Aug. 2, 2024 15:15:54
tamte
ch("../seed")+$FF
Ah this is true I found the gasseedfluidparticles1 and it does seem to be jittering. Maybe I just need to increase the animation speed of the mountain node to fix it.
