Hi everyone, I'm running into an issue with Karma when trying to render motion vectors. To get them working, I have to enable motion blur and disable image blur. However, when I do this, the object appears time-shifted, even though no actual blur is being applied to the image (which is what I'm aiming for).
I'm wondering why this happens. The view in Houdini GL looks fine, but when I switch to Karma, the object gets shifted. Is this behavior intentional, or am I missing something? Any insights would be greatly appreciated!
Rendering motion vectors in karma without modifying beauty
915 4 2-
- dkeraudren
- 11 posts
- AhmedHindy
- 144 posts
- tamte
- 9259 posts
I don't use Karma, but this happens in Mantra as well so I assume it's the same reason
it's because when MB is on even with Image MB off it renders the geo at Shutter Open time
which is likely -.25 or something by default and therefore you will see everything shifted
try overriding the Shutter Open to 0 and see if it fixes things
I however don't know the reason why this is a thing and if anyone ever found it useful
- AhmedHindy
- 144 posts
- tamte
- 9259 posts
AhmedHindyfor renders with Image MB disabled subtract shutter:open value on your camera from shutter:open and shutter:close esseentially offsetting shutter:open to 0
So naturally the shift in Karma is problematic in comp.
so -0.25 to 25 will become 0 to 0.5 etc
that way those renders will not be shifted and should more or less align with your nonMB Arnold renders
