Cook TOPS from python or HScript, verbose
   3223   1   0
Is it possible to “cook” a TOPS network from a external Python or HScript, via “hython” or “hscript”. (Like we would use “hou.node().render()” to render or cache) And would it be possible to get some information/status from the instances running on the different threads?
So I find a way to cook a TOP node with python code in the Houdini menu file:
# you can check the nodegraphtopui.py file in the Houdini installation folder
import nodegraphtopui as topui
node = hou.node("YOUR TOP NODE PATH")
# do cook
topui.dirtyCookNode(node)
Edited by EricSheng - 2019年8月6日 22:59:21
