FFmpeg Problem
   3922   4   1
Hey there,
I am using the following in my ffmpeg node(see image attached)
This worked on my windows at home but doesn't seem to work on my Linux centos 7
It gives me the following errors:
fmpeg version 2.8.15 Copyright © 2000-2018 the FFmpeg developers
built with gcc 4.8.5 (GCC) 20150623 (Red Hat 4.8.5-36)
configuration: –prefix=/usr –bindir=/usr/bin –datadir=/usr/share/ffmpeg –incdir=/usr/include/ffmpeg –libdir=/usr/lib64 –mandir=/usr/share/man –arch=x86_64 –optflags='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong –param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic' –extra-ldflags='-Wl,-z,relro ‘ –enable-libopencore-amrnb –enable-libopencore-amrwb –enable-libvo-amrwbenc –enable-version3 –enable-bzlib –disable-crystalhd –enable-gnutls –enable-ladspa –enable-libass –enable-libcdio –enable-libdc1394 –enable-libfdk-aac –enable-nonfree –disable-indev=jack –enable-libfreetype –enable-libgsm –enable-libmp3lame –enable-openal –enable-libopenjpeg –enable-libopus –enable-libpulse –enable-libschroedinger –enable-libsoxr –enable-libspeex –enable-libtheora –enable-libvorbis –enable-libv4l2 –enable-libx264 –enable-libx265 –enable-libxvid –enable-x11grab –enable-avfilter –enable-avresample –enable-postproc –enable-pthreads –disable-static –enable-shared –enable-gpl –disable-debug –disable-stripping –shlibdir=/usr/lib64 –enable-runtime-cpudetect
libavutil 54. 31.100 / 54. 31.100
libavcodec 56. 60.100 / 56. 60.100
libavformat 56. 40.101 / 56. 40.101
libavdevice 56. 4.100 / 56. 4.100
libavfilter 5. 40.101 / 5. 40.101
libavresample 2. 1. 0 / 2. 1. 0
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 2.101 / 1. 2.101
libpostproc 53. 3.100 / 53. 3.100
Unrecognized option ’apply_trc'.
Error splitting the argument list: Option not found
Executing command: “ffmpeg” -y -r 24/1 -f concat -safe 0 -apply_trc iec61966_2_1 -i “/tmp/houdini_temp/pdg_demo/pdgtemp/19628/ffmpeg_montage_p00_framelist.txt” -c:v libvpx-vp9 -crf 32 -b:v 0 -vf “fps=24,format=yuv420p” -movflags faststart “/home/suesauer/img/pdg_demo/ffmpeg_montage_p0/pdg_demo.ffmpeg_montage_p0.webm”
If I remove -apply_trc then it complains about -c:v libvpx-vp9. If I remove that it complains about it being an .webm
Is there something I need to install on my Linux to make this ffmpeg work?
Screenshot from 2019-10-04 16-56-00.png (80.2 KB)
How did you install ffmpeg? It looks like it was compiled with a few options disabled.
Is there somewhere in the documentation that states how I should be compiling it for pdg?
Not that I'm aware of. If you're not comfortable compiling your own copy, and you're not shy of utilizing 3rd party package repositories, you could install a pre-built version.
This is how I installed it on my machine:
*uninstall current version*
sudo yum install epel-release
sudo rpm -v --import http://li.nux.ro/download/nux/RPM-GPG-KEY-nux.ro
sudo rpm -Uvh http://li.nux.ro/download/nux/dextop/el7/x86_64/nux-dextop-release-0-5.el7.nux.noarch.rpm
sudo yum install ffmpeg ffmpeg-devel
Note: This uses a 3rd party repository, Nux Desktop. It is well known, but neither I or SideFX have looked into the safety of these packages.
Thanks so much for the help, that seems to have worked
