XPU tests (with sample scene)
33413
93
6
frostfx
2021年11月11日 4:04
The latest daily build has: Re-enable a second code optimization for Karma on Windows now that the MSVC compiler bug has been fixed that required disabling optimizations. is that related to the issue and should the rendertimes on linux vs win be now more at the same ballpark?
GCharb
2021年11月11日 8:46
frostfx The latest daily build has: Re-enable a second code optimization for Karma on Windows now that the MSVC compiler bug has been fixed that required disabling optimizations. is that related to the issue and should the rendertimes on linux vs win be now more at the same ballpark?Someone will have to install the latest build and render the scene, so we can find out!
chrism
2021年11月11日 10:12
Yes, you should notice a marked improvement in Karma CPU render times on windows in today's cut of 19.0.435.
Chris McSpurren Senior Quality Assurance Specialist SideFX
PaQ WaK
2021年11月11日 10:35
Rhino Vex - TR3970X - CPU Windows H19.0.383 : 05:53 H19.0.435 : 01.52 (Linux H19 : 01:38)
Edited by PaQ WaK - 2021年11月11日 10:37:12
Gameloft
2021年11月11日 10:56
PaQ WaK Rhino Vex - TR3970X - CPU Windows H19.0.383 : 05:53 H19.0.435 : 01.52 (Linux H19 : 01:38)Okay, that's what you'd expect between Win vs Linux - 10% to 25% speed increase.
Houdini Indie Karma/Redshift 3D
GCharb
2021年11月11日 11:58
Nvidia drivers suck under Linux, otherwise I would use Linux Mint instead of Windows 10 Workstation!
Andy_23
2021年11月11日 14:08
chrism Yes, you should notice a marked improvement in Karma CPU render times on windows in today's cut of 19.0.435. Excellent news.
GCharb
2021年11月26日 18:31
It looks like there is quite a bit of a speed gain in 449 compared to 383 with XPU using my GTX 1650, at least under Linux, great work SideFX. 383: 9:34 449: 7:13
Edited by GCharb - 2021年11月26日 19:09:48
Screenshot from 2021-11-26 18-25-58.png (1.8 MB)
2021年11月30日 7:40
well done i try to use karma XPU these time
mmj
brians
2021年12月3日 18:23
GCharb It looks like there is quite a bit of a speed gain in 449 compared to 383 with XPU using my GTX 1650, at least under Linux, great work SideFX. 383: 9:34 449: 7:13Hi
A quick question, when you have XPU enabled in the viewport, what devices are displayed (top right corner) and what percentage balance between EmbreeCPU and Opitx do you typically get?
thanks!
Edited by brians - 2021年12月3日 18:23:26
GCharb
2021年12月6日 8:28
brians Hi A quick question, when you have XPU enabled in the viewport, what devices are displayed (top right corner) and what percentage balance between EmbreeCPU and Opitx do you typically get? thanks!Optix: 52%
EmbreeCPU: 47%
CPU: 87%
Edited by GCharb - 2021年12月6日 08:29:33
Screenshot from 2021-12-06 08-26-26.png (2.3 MB)
HM_2020
2021年12月6日 19:19
Hey all, thanks for the awesome 19 updates! I need to add some flares to glittery particles, does XPU have any fancy bloom and flare post stuff like RS? Cheers!
GCharb
2021年12月24日 7:14
HM_2020 Hey all, thanks for the awesome 19 updates! I need to add some flares to glittery particles, does XPU have any fancy bloom and flare post stuff like RS? Cheers!I believe Karma has a lens shader VOP that can do that!
