How to stop Redshift noise animation
   4288   2   0
オンライン
I added the Rs_MaxonNoise texture to the model and set the rotation animation.
But Rs_MaxonNoise is also changing after rendering output.
One way I know is to modify the Noise Source value to "UV".
But I prefer the mapping method where the Source value is "Object". How can I cancel the Noise animation when the Source value is "Object".
Thank for your help!
Edited by HenDaSheng - 2023年4月28日 05:01:19
オンライン
I found the answer here [www.youtube.com], read the comments carefully.
Saw this video before asking, but didn't read the comments, which mentioned a solution to the problem without UVs.
Just in case anybody wonders how to do it without uv's, in case you are doing some proceduraly textureing, add a rest position node before any animation takes place, kind of the same but you won't have to create uv's - Max Rodas
This is caused because the Noise doesn't know how to compute the point deformation from the rubber toy, this kind of case is solved by just adding a rest attribute (only for constant topology).
I attached one video and one hip showing this.
Cheers!
rubber rest rs.hiplc (383.6 KB)
houdini_hVDmkQhblq.mp4 (3.1 MB)
