Karma Shader Precompilation H22
   912   5   2
Anyone else experiencing issues with the Karma shader precompilation in H22? It first took absurdly long (7h or so on an RTX4090) and it then ends with this error:
-------- Error Summary --------
PID: 37116
Command: karma --renderer BRAY_HdKarmaXPU -o husk:null_raster -p1 --res 1 1 C:/PROGRA~1/SIDEEF~1/HOUDIN~1.368/houdini/usd/karma/kma_precompile_shaders.usda
-------- 548 total errors --------
I've never had any issues with precompilation in H21 so not too sure what to make of this.
Edited by jemabaris - 2026年7月18日 13:56:17
Yep same here with the same gpu.
On a 4070Ti Super it doesn't error but does take a ridiculously long time. And it seems to be doing the compiling again and again for some reason ? It's repeating the same xx/548 whatever for the fourth time now. I'm pretty sure it didn't do this in earlier versions.
So I get the same error as you do at the end, jemabaris.
Plus, on Linux the compile took only 23 minutes, on Windows 11 was looking to take 10+ hours.
Rocky Linux 9.8, KDE
Threadripper 7980x w/ 128 Gb RAM
RTX 4090
Edited by TheNotepadShow - 2026年7月19日 08:05:40
Thanks,
Todd Manus
www.artstation.com/thenotepadshow
www.itodd.net
renderman.pixar.com/the-notepad-show
We've fixed the error-message at the end of the (you could ignore that stuff anyway).
The fix will be out in the first daily-build.
isamarsh
TheNotepadShow
regarding these two, we're still looking into it and with the aim to have it fixed by the first daily, thanks for testing + reporting back.
オンライン
@brians, so if i install the houdini-22.0.387-win64-vc143.exe, i should not have a problem when precompile render kernels ? What other things do i have to do when precompiling render kernesl in h22 ? I have an rtx 5080. Im reading on the internet that i have to add this code lines. KARMA_XPU_OPTIX_FORCE_OPTIXIR = 1 or # Forces modern shader compilation paths to support the RTX 5080 in Houdini 21
KARMA_XPU_OPTIX_FORCE_OPTIXIR = 1 or Forces OptiX to use proper intermediate representation to bypass Blackwell compile stalls
KARMA_XPU_OPTIX_ENABLE_OPTIXIR = 1
# Bypasses UI thread exhaustion when generating complex compute queues
HOUDINI_UI_QUEUE_SIZE = 99999
