Does H22 change how 456.py works?
1019
5
1
I have had the same issue, did you make a bug report? I'm thinking I'll make one.
I heard from SideFX Support that this problem was solved in Houdini22.0.386.
- cemg
I had the same issue, turned out the
456.py of the Labs was taking over.
Check if there is a file in here (for Windows), if so rename it and maybe copy its contents to your own file:
C:\Program Files\Side Effects Software\sidefx_packages\SideFXLabs22.0\scripts/456.py
akihito20x0
No it doesn't
jim707jim707jim
akihito20x0
No it doesn't
Oh. I reported a bug and received so from SideFX Support.
But I haven't tested it yet because I don't use daily builds.
If so, we should report the bug again.
